Where is my leak?
I am leaking a bit of coolant as well as oil. I can see the coolant is quite low on the motor--as in below the exhaust manifolds. The oil I know is coming from sump--I probably need a new gasket there and would be comfortable changing that out on my next oil change. My question is this, is it possible that where the block and sump meet that there would be coolant coming from there?
No, there are no coolant passages in the lower half of the engine.
The coolant flows around the cylinder walls, then up through the heads and out to the radiator, then back into the water pump to start all over again.
If it is leaking from below the exhaust manifolds you will need to figure out if it is coming from somewhere higher up and running down or if it is leaking from a head gasket.
If you clean up the engine and look really close you can tell where the heads mate to the block.
The mating area will be under the exhaust manifolds.
on
First, have you ever done a set of head gaskets before?
Second, don't wait till your next oil change to replace the head gaskets, order them today and get started or your engine may not make it to it's next oil change. especially if the gasket totally fails and you don't catch it in time.
ZMonet
06-24-2016 04:00 PM
lipadj46
07-08-2009 07:41 PM
