Whining at cold startup
Old Jul 14, 2013 | 05:41 PM
robersonb's Avatar
Default Whining at cold startup
Just thought I would let everyone know about an issue with my SAI that was hidden that others might have. I am currently taking my engine apart for head gaskets. My Disco has always made that whining sound at cold startup and I assumed at some point I would be replacing the SAI pump. However I happened to put my hand on the air tube leading from the pump and something didn't feel right. That tube is just plastic and mine had at metal heat wrap around it at where it makes the 90 degree turn up. Peeled that wrap away and sure enough it was split completely in two at that point. It may not solve my whining but I'm sure its part of the problem.
Old Jul 14, 2013 | 07:09 PM
P/S pump will sometime, when cold, whine at start up also.
Old Jul 14, 2013 | 07:18 PM
robersonb's Avatar
Yeah, I've seen that but mine is coming from that side of the engine and it was obvious. What wasn't so obvious was that under that heat wrap the tube was broken and collapsed. right at the 90 degree corner.
mattmo78
Nov 21, 2013 01:23 PM
pkppunk
Jan 26, 2013 07:05 PM
Raytelman
Aug 5, 2005 03:59 PM
Raytelman
Jul 27, 2005 10:44 PM
matthew.shore
Feb 17, 2005 04:16 AM
