whining noise
Old Jan 7, 2008 | 08:20 PM
jkid's Avatar
Default RE: whining noise
Yes Lucas additive has the stop leak in it. You may still have two different problems here though. Ifyou're covered by warranty I would just get it in have it checked out before you do anything. Dr. Mike?.....
Old Jan 8, 2008 | 08:43 AM
ezioc's Avatar
Ok. I called the dealer and they recommended that I not put any additives in. I also asked about filling the steering fluid to get it to the appropriate range before I drive up there. Onwers manualy states to use Texaco Cold Climate PAS fluid 14315. If I have trouble finding it, can I use the Valvoline synthetic fluid that I see mentioned on some of threads? Also if I do decide to use the Lucas additive, would that damage the system. Or should I add the bottle after the leak is found and fixed as a preventive measure. Right now the fluid mark is about 1/4 inch below the min line on the reservoir.
Please advise.
Old Jan 8, 2008 | 11:42 AM
jkid's Avatar
You can top it off with any fluid for now. Valvoline syn. is a good fluid if your replacing it. Lucas add. can be added at any time, you may want to add some when they are done working on it.
ggushee
Sep 30, 2015 08:49 AM
pierrejchan
Nov 11, 2008 11:27 PM
kae
Oct 24, 2008 10:02 AM
jhgerber
Feb 26, 2008 11:43 AM
chicksrover2
Dec 20, 2007 05:16 PM
