Whining Noise from 99 Discovery 2
Old Feb 2, 2020 | 08:54 AM
DiscoNewcomer's Avatar
Default Whining Noise from 99 Discovery 2
Hey Team,
looking for the right Discovery 2 to start my Land Rover journey with.
Found a well-maintained, low mileage 99 that seems just great.
However, when I took it on the highway and hit 60+mph it started making a whining noise. (Link below) just curious as to if it’s a critical problem with the Truck or something that’s as simple as changing out some fluids.
let me know what you think.
Old Feb 2, 2020 | 02:52 PM
XRAD's Avatar
hard to tell if it's drive train or electrical..... Alternators can whine with bad bearings. Trans and CDL can whine too.... Wheels bearing can whine.. less likely wind noise.
Try holding throttle steady at 2200 rpm (rpm on vid) while in park and see if you can hear it.....
Old Feb 3, 2020 | 01:21 PM
boston4's Avatar
Mine makes the same noise - it only comes on around 70 mph and sounds kind of electrical as if it's coming from the steering column area. It's a bit quieter than it sounds in the video but I assume it's the same.
I can't replicate the noise while in park or until it gets up to speed on the highway, which rules out a bad bearing or pulley. I ruled out drivetrain because it disappears if I take my foot off the gas - it's only when throttle is applied. Can't be wind noise if it's only throttle on.
No clue what it is. Been like that since I bought it - 6 months and 3k miles. I searched around for this a while ago and never found anything.
Old Feb 4, 2020 | 03:31 AM
shanechevelle's Avatar
Check the front driveshaft.
Old Feb 4, 2020 | 06:24 AM
boston4's Avatar
Definitely not applicable to me - noise only presents with foot on gas. Also, I replaced the driveshaft and the noise is unchanged.
Old Feb 4, 2020 | 04:26 PM
miron's Avatar
Most likely alternator - mine had the exact same whine. Take off the belt and run it for a minute and see if it's gone.
Old Feb 9, 2020 | 02:22 PM
toofaroffroad's Avatar
I had a very similar noise last year. Tracked it down to old worm pullys on the serpentine belt. Very cheap and easy to fix. Take the belt off and start the truck. If the sound is gone then it's a pully. Depending on which one it might only be a few bucks to replace. also a good opportunity to replace your belt if need be.
It's the bearings in the pullys. They start to whine when the trucks get older.
jrwalk1651
Nov 20, 2015 08:39 AM
89Mike
Feb 10, 2011 09:38 PM
lagwagon
May 30, 2008 06:03 PM
pickps
May 14, 2007 12:42 PM
msbont
Sep 10, 2006 03:53 PM
