Whirring sound!
Whirring sound!
I get a whirring sound on initial acceleration, it sounds like it is coming from one of the belt driven elements, my friends has a similar sound but not quite as loud, it seems to peeter out above 2000 RPM. Any thoughts?
Also my brake pedal travel is quite long on the first push and then is normal and much more responsive on the second pump! Fluid level is ok and brakes are only 15k old.
RE: Whirring sound!
same sound on mine, diagnosed it as the tensioner pulley. good idea to change tensioner, idler pulley and belt at same time. waiting for mine to arrive.
Brake pedal- i have read on hear that brakes are a little more sensitive than many other trucks (primarily american). I have felt same on mine. Try a good brake bleed with syntheic fluid
RE: Whirring sound!
ORIGINAL: larryrover
HelenaRover
09-14-2010 11:43 AM
