Whirring sound!
Old Jan 14, 2008 | 09:54 PM
larryrover's Avatar
Default Whirring sound!
I get a whirring sound on initial acceleration, it sounds like it is coming from one of the belt driven elements, my friends has a similar sound but not quite as loud, it seems to peeter out above 2000 RPM. Any thoughts?
Also my brake pedal travel is quite long on the first push and then is normal and much more responsive on the second pump! Fluid level is ok and brakes are only 15k old.
Old Jan 15, 2008 | 10:47 AM
zerochills's Avatar
Default RE: Whirring sound!
same sound on mine, diagnosed it as the tensioner pulley. good idea to change tensioner, idler pulley and belt at same time. waiting for mine to arrive.
Brake pedal- i have read on hear that brakes are a little more sensitive than many other trucks (primarily american). I have felt same on mine. Try a good brake bleed with syntheic fluid
Old Jan 15, 2008 | 12:04 PM
spoon's Avatar
ORIGINAL: larryrover
Sounds like air is leaking into the braking system somehow. I don't know too much about what parts of the Disco brake system are more succeptible to failure than others, but it definately seems like air in the system. Have you had your brakes done recently? Bleed 'em and report back. Also check to see if the cap on your brake fluid resivoir is securely tightened.
Old Jan 15, 2008 | 07:56 PM
larryrover's Avatar
thanks I think you nailed it! gonna change them tomorrow and the bleed.
Cheers!
Old Jan 15, 2008 | 08:02 PM
larryrover's Avatar
By the way.....when Chuck Norris does a push-up, he doesn't push himself up. He pushes the world down!
Old Jan 15, 2008 | 09:48 PM
Mark G's Avatar
Double-check the fan clutch. Just spin the fan and it should spin freely with some resistance. If it is tight, replace. Mine was stuck (shot). Autozone -> $150 and they had the tool to change it.
RegT
Apr 7, 2013 07:32 PM
HelenaRover
Sep 14, 2010 11:43 AM
pprideaux
Aug 22, 2010 07:13 AM
deeppockets
Aug 27, 2009 09:22 AM
Disco Kiwi
Jan 31, 2006 07:13 PM
