Whistling from intake manifold area
Old 01-13-2014 | 09:12 AM
Bob Loblaw's Avatar
Default Whistling from intake manifold area
I have a whistle that shows up after the truck warms up. I used a small hose as a ghetto stethoscope and found that the noise is coming either from the seam that I am pointing to with the screwdriver or somewhere underneath that piece where I can't reach the hose. (Driver's side of the engine, under the throttle body area)
If I had a vacuum leak here, I would expect a CEL with some lean codes, but it's been whistling for over a week with no codes.
Am I thinking about this correctly?
Attached Thumbnails Whistling from intake manifold area-photo-1.jpg   Whistling from intake manifold area-photo-2.jpg
Old 01-13-2014 | 09:34 AM
coors's Avatar
Vacuum leaks will not always throw a cel. Are you sure no one mysteriously stuffed a supercharger in there while you were away from your truck?
Old 01-13-2014 | 09:57 AM
Bob Loblaw's Avatar
Haha I don't think so.
I forgot to add that the whistle goes away when I step on the gas, which would point to a vacuum leak, correct?
Old 01-13-2014 | 11:48 AM
cowan's Avatar
7th Gear
If you think you have a vacuum leak spray some carb clean all around the area and see if the rpms change. If the vacuum leak is very minor the ecu can adjust fuel trim for it. If it has to adjust too much it will set a dtc and the light. And yes.. when you open the throttle vacuum goes down in the intake so vacuum whistle will go away.
Old 01-13-2014 | 02:10 PM
OffroadFrance's Avatar
Cast iron LR exhaust manifolds are notorious for distorting and letting out exhaust. The exhaust manifold on my TD5 started with a slight whistle that got progressively worse and started causing other problems. Although the simplest thing is to throw on a new manifold, it will, in time also distort and cause another similar problem due to heat stress relief in the casting. What my guy did was to have the manifold skimmed and then bolted it back with new gaskets, that way the distortion is eliminated for good. Unfortunately one of the studs broke in the head and required drilling out and a Helicoil insert - but that's another story.
Old 01-14-2014 | 07:14 AM
drowssap's Avatar
let the truck cool, spray the area with clear laqueur paint, and let it dry. The next time to drive your truck if it does not whistle you have a vacuum leak.
Old 01-14-2014 | 08:43 AM
Jawbox's Avatar
Mine had a god awful whistle that went away when I had the intake gaskets replaced. It never threw a code.
Old 01-14-2014 | 09:05 AM
Bob Loblaw's Avatar
I just did a bunch of work on the truck a few weekends ago, which included replacing the intake gasket. I just wanted to make sure I was heading down the right path before I start working on it again.
Old 01-14-2014 | 10:24 AM
xxdoylexx's Avatar
Yep vaccum leaks are most noticible under idol.
caulk isnt a option, lol
jsyonker
11-12-2012 09:15 PM
brw1982
07-21-2008 11:42 AM
bal51365
10-10-2007 09:36 AM
sealluke
12-17-2006 11:58 AM
jbriggs
07-14-2006 01:07 AM
Quick Reply: Whistling from intake manifold area
