Whistling noise
landroverdude (03-11-2020)
Could be a pulley. You can remove the serp belt, and fully inspect the belt and spin/shake each pulley to see if it's worn. You can also run the engine without the belt for about a minute or so to hear if you still have the whistling noise.
Also check your power steering fluid level. Could be steering pump groaning from air in the fluid system or a pump going bad.
KernowDiscovery
05-30-2014 10:44 PM
