White gauge faces
Old Feb 18, 2015 | 09:36 AM
Jnj's Avatar
Jnj
Default White gauge faces
Hi I'm wanting to update the interior of the disco 2. Adding a flip up 7" DVDs and navi unit. I want to update the cluster. Has anyone installed the white faces that are out there and maybe some led bulbs? I like the look of the 03/04 cluster faces vs my 01. Are they compatible to swap the entire cluster?
Old Feb 18, 2015 | 09:54 AM
dusty1's Avatar
The clusters are direct swap
You can use led bulbs
You will have to get a response from a more fancy person on the DVD stuff, but it's doable
Old Feb 18, 2015 | 11:28 AM
slammin_LWB's Avatar
IIRC you need to have the cluster programmed or the mileage will just flash.
Old Feb 18, 2015 | 11:30 AM
dusty1's Avatar
oh yeah, left that out. thanks lwb
Old Feb 18, 2015 | 11:49 AM
Jnj's Avatar
Jnj
Got that part. Will have it reflashed.
I've sources a 03 cluster. Going to skip the white faces. But I want to do led bulbs throughout the cabin. Is T5 the correct size bulb for gauge cluster, hvac controls, clock etc?
Old Feb 18, 2015 | 05:10 PM
OffroadFrance's Avatar
Default Changing an instrument binnacle.
Hi, does anyone know whether I can just swap over the whole instrument binnacle (speedo, rev counter, fuel and temp gauges, warning lights etc) or does it need to be synched to the ECU and/or alarm system?. Is it an easy job to sort out?.
Old Feb 18, 2015 | 05:11 PM
abran's Avatar
Needs to be synced. If not the read out for mileage and gear selection will be flashing.
Old Feb 18, 2015 | 05:13 PM
Sorry, it was meant to be a new thread I don't know what happened there
Old Feb 18, 2015 | 05:14 PM
abran's Avatar
^ I answered the new thread as well!
warchuswest
Appearance & Camping Set Ups
Sep 25, 2014 04:36 AM
Rover_Hokie
Feb 2, 2014 03:52 PM
sloppyjoe
Dec 11, 2008 09:48 PM
Sights N Sounds
Mar 9, 2006 12:42 AM
englishboyonice
Mar 28, 2005 08:41 PM
