Who had use time serts?
Old Jun 28, 2021 | 07:45 PM
zacharyz28's Avatar
I think at this point I will just get bolts. I don't want to wreck another block.
Old Jun 29, 2021 | 12:47 PM
Richard Gallant's Avatar
Just to note stud kits vary a lot the Rover V8 kit is shorter some cheaper ones are too long. Lots of brit use them on older small castings, that said they worked fine on my 4.6.
​​​​@Extinct has a good point if a bolt or stud "feels different" that can be an issue.
And chase and clean the threads, I used, degreaser, followed by hot water and a heavy concentration of dish wash soap, hot water, then cheap isopropyl alcohol. I found a pipe cleaning brush that fit in the bolt holes nicely.
Old Jun 29, 2021 | 07:36 PM
zacharyz28's Avatar
Well i got the studs from Lucky8 with their head gasket kit so I don't know the part number. How long are the studs supposed to be?
Old Jun 29, 2021 | 07:59 PM
@zacharyz28 You should be fine double check the torque specs they are a lot lower than they were originally were around only 70lbs now I think - APR has the update on their website.
Go easy on the lube too
Old Jun 30, 2021 | 11:10 AM
zacharyz28's Avatar
I admire your confidence but I am still rather gun shy. I had it at 80 last time when they pulled out which is was some sites listed as the final value. My fault for not reading the actual supplied directions. But 10 lb/ft between spec and pulled threads combined with horror stores of them pulling at 50 doesn't instill me with confidence.
Old Jun 30, 2021 | 11:20 AM
@zacharyz28 Yea that is the problem with old stuff lot of people have worked on it. All I know is mine went in clean.
DiscoBuckeye
Oct 18, 2018 09:31 AM
blmw
Member Group And Special Buys
Mar 26, 2012 12:15 PM
94svt50
Jan 19, 2012 11:50 AM
FightOnUSC79
Feb 15, 2011 12:41 PM
vandev
Aug 15, 2010 09:38 PM
