Whoa!! Is this bearing grease all over my brakes!?
Old Mar 7, 2013 | 02:05 PM
cobbcj7's Avatar
Default Whoa!! Is this bearing grease all over my brakes!?
I was doing a brake job and came across this!! Now what? New seal? Failed bearings? Just clean it up??
Thanks
Attached Thumbnails Whoa!! Is this bearing grease all over my brakes!?-image.jpg
Old Mar 7, 2013 | 05:14 PM
jafir's Avatar
Clean it up and see if you can see where it's coming from. Could just be o-ring on the bearing hub assembly. Could be the bearing.
Old Mar 7, 2013 | 05:44 PM
Check your gear oil level, if it is low, it could be the o-ring if not low it could be the inner seal on your hub and you will need to replace it.
Old Mar 7, 2013 | 06:06 PM
94svt50's Avatar
Most of the time its the hub, which has to be replaced as a unit. You might get lucky and it might be the o ring but I doubt it. Mine looked just like that and it was the hub.
Land Rover Hub Assembly W/ ABS Sensor (Rear) (Same Fit As Genuine Part # TAY100050)
Old Mar 7, 2013 | 07:58 PM
iambhooper's Avatar
the right rear went on mine 15 month's ago. we just replaced the outer seal and haven't had any more problems.
Old Mar 8, 2013 | 10:51 AM
cobbcj7's Avatar
Question O-Ring? Gear oil level?
For the sake of saving money I would obviously like to try the O-ring or outer seal first before buying a new hub.. Is the o-ring an easy fix? I am very well skilled in fixing trucks so I have no problem doing things myself.. I assume putting my new brake set-up on with gear oil everywhere is a bad idea...
Also checking gear oil level.. is there an eye-hole? how do I check it on the Disco??
Thanks a ton guys
Old Mar 8, 2013 | 11:20 AM
see attached from RAVE shop manual, which you need to download for light reading of "Brit Lit".
Also, in case it has not been mentioned, there is a vent line from the axle that runs from a banjo bolt up to a "shepherd crook" vent. Ths allows oil vapor to escape when it evaporates. If plugged with mud chiggerz, it can build up a slight pressure and vent axle oil thru the hub seals. So be sure to remove the banjo bolt and clean it and blow out the line.
File Type: pdf
Old Mar 8, 2013 | 03:17 PM
ralphobell's Avatar
I had same problem. Replaced O-Ring and did not solve the problem. Purchased 2nd hand Hub. But before I replaced it I put some White Shepherd/Blue Devil in the differential after replacing the gear oil with 85w-140w. It cured the leak. But I still have the HUB if needed in the future.
Old Mar 8, 2013 | 03:36 PM
cobbcj7's Avatar
Question Gear oil
As for replacing the gear oil, I was going to go with the 85-w140. But for the grease? is the dif oil the same as the grease I'm getting at the hub? Which grease to I use for the hub? Is it the heavy gunk grease??
Thanks again as always
Old Mar 8, 2013 | 10:05 PM
If it is diff oil, it mixes with brake dust to make a rubbery gunk.
