why i cant bleed the coolant system on a D1
Old Mar 11, 2010 | 11:09 AM
christianmotox's Avatar
Thanks for all youre good input guys.
I don't remember seeing a bleed screw on the Thermostat housing, but ill go there and double check.
and i guess ill try it out with out reeving the engine, and ill make sure i remove the bleed screw from the radiator and fill the reservoir until i see coolant coming out of the bleed screw.
Ill do that later today, cause i just got in to work and the Disco is still hot.
Again, thanks for all you're quick responses.
Old Mar 11, 2010 | 11:14 AM
if i cant get it to bleed today, ill just go ahead and buy a genuine Thermostat, since the one i replaced is not genuine.
Old Mar 12, 2010 | 09:50 AM
The t/stat is not going to have anything to do with the out come of your bleeding efforts. If bleed as I posted before, all the air will be removed from the top of the engine and you'll be done.
Old Mar 12, 2010 | 10:01 AM
johnkbl's Avatar
Hey Christian, please let us know if you could finally bleed your system. I will replace my coolant next week and would like to know how you solved your problem just in case I have a similar one.
BR
Old Mar 12, 2010 | 10:31 AM
Shane83's Avatar
If you follow my steps, step by step, you will be just fine man.. its not all that difficult, just take your time and don't rush it!
Like Disco Mike said you wont need a new thermostat, once the air is out, the vehicle will run just fine!
Best regards my friend,
jfall
Jan 29, 2016 09:38 AM
Creed0330
Apr 28, 2014 06:53 PM
khandrh
Sep 2, 2013 05:30 PM
Savannah Buzz
Nov 29, 2011 09:40 PM
JavaDiscoII
May 29, 2010 04:33 PM
