Why make non greasable u-joints to begin with?!?!?
A lot manufacturers DO NOT include zerk fittings on their drive shafts. Land Rover is not alone in this area. It's cheaper, and eventually the dealerships can make $$$ replacing them.
Anyone that does their own routine maintenance or off road's their LR would be checking them on a regular basis. Grab one off of Ebay with zerk fittings for 125.00-150.00 and be done with it. Any LR I buy = a new drive shaft is one of the first orders of business.
Ok. So I'm not a mechanic, but how does the centering ball relate to the non-greasable u-joints? I recently had vibration if I went above 75 mph, but after getting the front and rear shafts cleaned I don't have any vibration at all. I feel like the drive shaft will warn me when its about to fail, either by chirping or intense vibration.
Also, mind sharing which drive shafts you guys bought for the DI/II? Does Land Rover use non-greasable u-joints for most if not all of their model vehicles?
Sorry for the onslaught of questions, I'm new to the forum and only 22 still learning about maintaining these trucks on a budget. Thanks so much and really appreciated!
" I feel like the drive shaft will warn me when its about to fail, either by chirping or intense vibration. "
First, PLEASE DON'T use that "logic" when it comes to DII drive shaft!!! Just replace this thing NOW!
The drive shaft WILL warn you, by saying in a polite voice, " Please check your AT it has a BIGA$$ HOLE in it! "
The front drive shaft from Lucky8 (L8 is a board sponsor) is a very good choice. Either from their site or ebay store you won't go wrong.
Great guys to deal with.
> https://www.lucky8llc.com/collection...t-driveshaft-6
> https://www.ebay.com/itm/LAND-ROVER-...ZXMByM&vxp=mtr
The following 2 users liked this post by OverRover:
dasherman (12-26-2017),
TriggerPuller (01-28-2018)
Manufacturers build to last the length of the warranty, with minumum maintenance. Soccer moms don't care about grease fittings, so take them out of the equation. Once warranty is over, manufacturer is more than happy to fix your problems, on your dime, with their high labor charges and high cost repair parts ($$$profitable).
