Why make non greasable u-joints to begin with?!?!?
Old 12-31-2017, 09:20 PM
OverRover's Avatar
Originally Posted by dasherman
I just read somewhere that the greasable u joints will lose their grease and dry out faster because the DII drive shafts are too close to the exhaust? Not sure about this but I'll check under the vehicle tomorrow. If anyone can confirm or deny before then that would be great. Thanks!
Greasable joints or non-greasable......It's true that the location of the U joints next to the cat/exhaust doesn't help the lifespan of the joints.
BUT that's why you get a GREASABLE U joint drive shaft to add grease to extend the life of the joints. Hit the U joints with some grease at every oil change and life is good. Simple routine maintenance.
Here have a look, I'll save you a trip under the truck
dasherman (12-31-2017)
Old 12-31-2017, 09:25 PM
dasherman's Avatar
Ahh bullet proof logic. Thanks for the help and will be ordering up a new drive shaft soon! Cheers!
Old 12-31-2017, 09:53 PM
OverRover's Avatar
Smart man!
You will not regret replacing the drive shaft way BEFORE it becomes a problem.
Old 01-01-2018, 03:48 AM
The Deputy's Avatar
Received 1,278 Likes on 897 Posts
Default Don't let this happen to you...
This was the condition of my trans when I bought my 01. Original shaft let loose, non-greaseable, 132K.
Took out the y-pipe, too.
^^^^Notice...pre-rover work bench.
Post rover work bench....lol.
Brian.
dasherman (01-01-2018)
Old 01-01-2018, 09:21 AM
Originally Posted by ZGPhoto
Because most people that bought the vehicle originally wouldn't grease them. And the U-joints aren't the problem, it's the centering ball.
X1 .... that and cost of production, every penny counts, that's why Ford always design to use 2 bolts instead of 3. Bearing in mind most D2's only stay with the original buyer/owner for 3 years max until the warranty expires and are then traded into the open market.
Old 01-01-2018, 09:25 AM
You've got a very clean bottom OR, damn, underneath eh
Old 01-01-2018, 09:28 AM
[B]" .......................... " Please check your AT it has a BIGA$$ HOLE in it! "
Excellent
Old 01-01-2018, 09:09 PM
dasherman's Avatar
Thanks for all the help guys, really appreciate it. Also, I know this is an old question, but what oil do you guys run? I have been running Mobil 1 synthetic extended performance 10W-30 in it since I bought the car at 65k miles on it. It has 85.3k on it now and after doing some research I'm not sure if I should keep running synthetic or switch it to regular oil. I also feel like I should run 5W given how cold it's been lately (-16 w/o windchill tonight). Do you guys run 30/40 and what brand?
Old 01-02-2018, 09:57 AM
ZGPhoto's Avatar
10w-40
Old 01-02-2018, 10:23 AM
discosteve-MMI's Avatar
5w-40 synthetic here. Temps have been -10 to -20 Deg C. Truck has been running great!
austinlandroverbill
07-05-2017 11:11 AM
Jared9220
06-08-2014 11:49 PM
JBEGIN
12-06-2008 01:14 PM
discobob
06-09-2008 08:40 PM
bigugly82
10-09-2007 03:58 PM
Quick Reply: Why make non greasable u-joints to begin with?!?!?
