why is my D2 killing O2 sensors
Old May 11, 2017 | 02:53 PM
dougn's Avatar
Default why is my D2 killing O2 sensors
my O2 sensor keeps going out on bank A. first I get p 130 then 171. I take my sensor out and bench test it and yeah it's dead. I have some oil in my connector that I washed out but the sensor itself is dead. the oil doesn't appear to be getting into the sensor
Old May 11, 2017 | 07:14 PM
Extinct's Avatar
Bad news Amigo, you likely have a blown head gasket. Antifreeze usually is what kills the sensors...
Old May 11, 2017 | 07:16 PM
dougn's Avatar
I wonder how much it takes. I don't notice much/any coolant loss
Old May 11, 2017 | 11:09 PM
Alex_M's Avatar
Also check for possible shorts in the wiring harness. Might be getting shorted out and cooking the little ba*tards.
Old May 12, 2017 | 05:19 AM
Extinct's Avatar
I should have added, if it is only one side that is dying it is almost a sure thing that side is leaking coolant. It is possible both sides are doing it, but I usually see them where only one is the offending side.
Old May 12, 2017 | 09:41 AM
dougn's Avatar
well that's it, im done!
Old May 12, 2017 | 11:20 AM
Dave03S's Avatar
Take a look at the spark plugs on the offending side... If you have an internal HG leak or a compromised block you will see the signs.
Old May 12, 2017 | 11:42 AM
dougn's Avatar
yeah I will install a new sensor and run it for a while, then look at the plugs. im sure they're probably dark now since it's been running rich for 10 miles or so
Old May 13, 2017 | 01:01 PM
Extinct's Avatar
They actually don't run rich just because the sensors die - the ecm just reverts to programming where it will use a combination of MAF sensor readings and speed density programming (engine speed and manifold pressure) to determine fueling and spark timing. Unless you are at Altitude or have modified the engine it will run very close to stoich most of the time.
Still does not change your head gasket issue though....
Old May 13, 2017 | 01:52 PM
dougn's Avatar
well it definitely runs rich when this happens. it smells and the O2 sensor comes out sooty
