Why not go with the 3" OME? (vs 2")
Old Oct 13, 2009 | 08:49 AM
oysterhead's Avatar
Originally Posted by antichrist
The biggest factor is at 3 there's a good chance you're going to start having steering geometry issues, which can add a lot of dollars to the overall cost in order to correct.
now that's a drawback!
seems interesting that just one more inch would lead to steering issues.
anyone on here run into geometry issues with their 3" OME?
Old Oct 13, 2009 | 08:56 AM
I agree.
The real question is why do you think you need a 3" OME instead of 2"? To get the OME to 3"s, you have to get creative and use a 751 D1 front coil along with the 763 cargo coils that will beat you to death because of their weight rating.
What sort of trails are you planning to run where you think a 3" is required?
If you really must have a 3" and you never plan to park it in a garage or public parking area, the use the 3" RTE coils.
Old Oct 13, 2009 | 09:08 AM
okdiscoguy's Avatar
I can't believe this was almost a page before someone mentioned sterring issues. Also get pinion anlge correction and brake lines...
Old Oct 13, 2009 | 09:54 AM
oysterhead's Avatar
Originally Posted by Disco Mike
I agree.
before you asked why, i asked why NOT?? hah.
so far we have steering geometry, pinion angle, parking garages, stiff ride, and short people.
it's interesting that one extra inch is such a big difference. one inch! it's not like i'm trying to squeeze on 35s.
not sure if it has the 751 and 763 coils, but this is the kit i'm talking about: http://www.lucky8llc.com/Products.asp?ProductID=2171
Old Oct 13, 2009 | 10:48 AM
A true 3" lift will shift both front and rear diffs. quite a bit to the drivers side, this will effect your turning radius and well as your pinion angle that if being used hard, will need to be corrected using new radius arms in the front and trailing arms in the rear as well as replacing your pan hard rod with an adjustable one so you can recenter your wheels, front and rear.
So as for your statement, there are way to many reasons to not do it then to go to a 3'". By the way, I have nearly a full 3" lift and am speaking from experience.
Old Oct 13, 2009 | 11:16 AM
WhiteD1's Avatar
5th Gear
You do not have to mix and match the ome springs. For 3 inch OME you use...OME 748's and OME's 747's for shocks you use N174's and N175's. Springs were specifically designed by OME for 3 inch use on D1's and RRC's.
Old Oct 13, 2009 | 11:28 AM
oysterhead's Avatar
A true 3" lift will shift both front and rear diffs. quite a bit to the drivers side, this will effect your turning radius and well as your pinion angle that if being used hard, will need to be corrected using new radius arms in the front and trailing arms in the rear as well as replacing your pan hard rod with an adjustable one so you can recenter your wheels, front and rear..
is the OME kit a true 3" lift?
If not, is it any less "drastic" than the RTE in terms of side effects/drawbacks?
Old Oct 13, 2009 | 03:13 PM
He is driving a D2, not a D1.
Old Oct 13, 2009 | 03:15 PM
Understand, I drive on OME's, I really like them, but the 763 rear springs required for the rear lift is really harsh.
It's a true 3" lift if you are not running a front bumper and winch, this will pull you down to a 2.5" lift in the front.
Old Oct 13, 2009 | 03:50 PM
WhiteD1's Avatar
5th Gear
My mistake...sorry didn't catch that.
