Why Spend the $$$$? Regular vs Premium
Old Jan 22, 2009 | 09:27 PM
unimoged's Avatar
Default Why Spend the $$$$? Regular vs Premium
My 2000 SD has been devouring regular unleaded at 15 MPG for the last 60,000 miles with no performance issues whatsoever like pinging, starting, power loss or anything else.
I maintain it religiously but I drive it hard and it runs as good as the 2004 SE7, that I bought 3 weeks ago.
Doing the math on savings:
[ul][*]60,000 miles / 15 MPG = 4,000 Gallons used.[*]4,000 Gallons X 30 cents per gallon difference = 1,200 dollars in my pocket. [/ul]
It is hard to imagine 4,000 gallons used or 28,000 lbs (for the folks that fly aircraft).
Has anyone used regular unleaded for thousands of miles. Any problems?
Contemplating placing the SE7 on the same diet. Any recommendations?
[IMG]local://upfiles/12736/5849729999CF45469313BF37B29CDFD5.jpg[/IMG]
Old Jan 22, 2009 | 09:35 PM
sloppyjoe's Avatar
Default RE: Why Spend the $$$$? Regular vs Premium
when looking to buy my 04' i read of several people who after long periods of time having large amounts of carbon build up from regular fuel.
secondary benefits are the cleaner longer burn mean better mileage and more efficient power made.
Old Jan 22, 2009 | 10:12 PM
lrd2's Avatar
i have used mid grade gas for 15k miles and now i need 4 new o2 sensors plus like 9mph so i will continue using premium its only like 10 cents of a diffrence
Old Jan 22, 2009 | 10:15 PM
Jupiter Rover's Avatar
Factor this in.
You get better MPG with Premium. You will save more money with premium.
Old Jan 22, 2009 | 10:16 PM
sloppyjoe's Avatar
i can run 87 in my ferrari and my ducati,,,
does not mean that i should,,,,
Old Jan 22, 2009 | 10:24 PM
I read that fast and thought you said you run 87 in your ferrari and ducati. I was about to blow a fuse.
Old Jan 22, 2009 | 10:26 PM
sloppyjoe's Avatar
ORIGINAL: Jupiter Rover
hahahhahahhaha that would blow a few around here
Old Jan 22, 2009 | 11:03 PM
hazletbassist89's Avatar
There's 2 things you didn't factor though. You're getting 15 mpg on 87. If you ran 91 or preferably 93 you'd probably get about 18 mpg. And also you have to remember that these engines aren't designed to run on regular, they wear prematurely, don't put out as much power, and gunk up very quickly when running regular, so our all ready high maintenance is increased by using premium. Believe me, I ran 87 for a year because I just didn't know better, and noticed a HUGE difference in fuel economy and power immediately, and now I'm really starting to notice the difference in maintenance.
Bottom line is, the manual says use premium, use premium.
Old Jan 22, 2009 | 11:15 PM
Disco Fuego's Avatar
Hi all,
So what about the fact that our Rovers should be world travelers? What would happen when we drive down to Central and South America and run on poor gas for 20K miles? Could that cause problems with the electronics? What could I do to prevent those problems? Octane boosters? I wouldn't want to drive with my trunk full of Octane boosters either... And I definitely don't want to prove the people right that told me I should have bought a Land Cruiser instead!
Cheers!
Old Jan 23, 2009 | 12:34 AM
NiteTrain's Avatar
ORIGINAL: lmvanhulst
Hi all,
Cheers!
step 1: buy a TDI rover
step 2: drive to central or south america
