Will I regret going to street tires?
Currently running 265/75/16 Federal Couragia MTs they are wearings and are loud.
I don't off road as often as I use to, if at all anymore really.
My buddy can get deals on mastercraft tires. I was deciding between the courser AXT and the courser HSR tours.
My fear going with the AXT is the noise and quick wearing.
My fear going with the HSR is if I ever do decide to go offroading it will have to be a dry day. Also the not so aggressive look.
ehh, it all depends on what your wants and your needs.
I don't offroad anymore, so I went with street tires. I actually have a set of General Grabber AT2's on 16's in my basement and because I don't offroad anymore, running L322a 19's with 255/50/19 Continental 4x4 Contact tires. Yea, I don't look like I'm going on a safari anymore but my needs and wants aligned in this case, so it doesn't bother me.
If Im reading into your message correctly, you want the offroad look, but not the offroad noise and wear? then my friend, you gotta pay to play.
my .02
I went with a winter tire set up for year around
Yokohama Iceguard IG51V
The tread pattern is rated for mud/snow/ice and the rubber compound is rated for low road noise and low wear. Zero issues from my side but, look at the ratings below from Tirerack
Survey Stats
258,189 Total Miles Reported
2 out of 7 in Light Truck/SUV Studless Ice & Snow Tires
97% vs. best in Light Truck/SUV Studless Ice & Snow Tires
Would You Recommend? 8.8 - Excellent
Wet Performance 9.0 - Excellent
Dry Performance 8.6 - Excellent
Winter/Snow Performance 9.4 - Excellent
Comfort Performance 8.1 - Good
Treadwear Performance 8.6 - Excellent
Survey Stats
