Will an ignition lock for a Disco1 work for a Disco2?
Old 10-03-2019 | 03:35 PM
Nick Johnson's Avatar
8th Gear
Default Will an ignition lock for a Disco1 work for a Disco2?
My disco 2 ignition lock is destroyed. I need the complete assembly all the way to the end of the cables. Not just the cylinder. There is a huge price difference in the disco1 and the disco2. They look the same. Will they fit the same? If not, do I have any other options?
Thanks!
Old 10-03-2019 | 05:02 PM
mollusc's Avatar
you can also get rid of the lock entirely and go with a push-button option, per this thread: https://landroverforums.com/forum/di...n-start-94316/
Old 11-06-2019 | 03:47 PM
Llamasayswhat's Avatar
Anyone know? they look identical, and AB is selling them to fit D2, but wont answer if the mechanism is the same...
Old 11-06-2019 | 06:54 PM
Best4x4's Avatar
The black plastic switch is different between a D1/D2 (part which plugs into the fuse box). The actual mechanical lock part is the same.
Old 11-07-2019 | 04:52 PM
So swapping the electrical component(The actual ignition switch, not the lock tumbler/housing) to the new housing should make it good to go
I ordered one for a D1 from BPUtah, and will do the swap next week
Old 11-07-2019 | 05:52 PM
Best4x4's Avatar
Yep it should be PNP after you swap the black plastic switch out.
Llamasayswhat (11-07-2019)
Paul Aspen
11-12-2013 08:40 PM
zacharyhatfield
05-07-2013 04:46 PM
1998DiscoverySE
06-27-2012 02:56 PM
brian891
09-02-2009 11:57 PM
autocckr2
07-16-2008 09:50 AM
Quick Reply: Will an ignition lock for a Disco1 work for a Disco2?
