Will an ignition lock for a Disco1 work for a Disco2?
Old Oct 3, 2019 | 02:35 PM
Nick Johnson's Avatar
8th Gear
Default Will an ignition lock for a Disco1 work for a Disco2?
My disco 2 ignition lock is destroyed. I need the complete assembly all the way to the end of the cables. Not just the cylinder. There is a huge price difference in the disco1 and the disco2. They look the same. Will they fit the same? If not, do I have any other options?
Thanks!
Old Oct 3, 2019 | 04:02 PM
mollusc's Avatar
you can also get rid of the lock entirely and go with a push-button option, per this thread: https://landroverforums.com/forum/di...n-start-94316/
Old Nov 6, 2019 | 02:47 PM
Llamasayswhat's Avatar
Anyone know? they look identical, and AB is selling them to fit D2, but wont answer if the mechanism is the same...
Old Nov 6, 2019 | 05:54 PM
Best4x4's Avatar
The black plastic switch is different between a D1/D2 (part which plugs into the fuse box). The actual mechanical lock part is the same.
Old Nov 7, 2019 | 03:52 PM
So swapping the electrical component(The actual ignition switch, not the lock tumbler/housing) to the new housing should make it good to go
I ordered one for a D1 from BPUtah, and will do the swap next week
Old Nov 7, 2019 | 04:52 PM
Best4x4's Avatar
Yep it should be PNP after you swap the black plastic switch out.
Paul Aspen
Nov 12, 2013 07:40 PM
zacharyhatfield
May 7, 2013 03:46 PM
1998DiscoverySE
Jun 27, 2012 01:56 PM
brian891
Sep 2, 2009 10:57 PM
autocckr2
Jul 16, 2008 08:50 AM
