Will a Snap-On Ethos Pro program SLABS?
I need to turn off the SLS since I have coils and while I'm in there I also want to disable superlock for the obvious reasons.
1) I have free access to this unit (drive 15 miles and plug it in) so I wanted to see if any of you knew for sure if it will or will not work.
2) Is there anything else I should address while I'm in there?
Thanks in advance.
Thanks in advance.
Originally Posted by Best4x4
Not sure if a Non LR designed scantool can make BCU/SLABS Unit changes, but go try it and let us know. I have a friend with a SnapOn scantool and I know it can reset Adaptive settings and ABS faults. I never tried to use it for programming though.
The shop that swapped the air springs for coils on my truck years ago failed to change the SLABS setting, so I took it back to them later once I figured out the cause of a parasitic battery drain was the SLS pump. I had them also disable superlock that day. Took all of five minutes, if that.
The Autologic can also sync the instrument panel and the BCU. Mine got out of sync earlier this year so I stopped by a different local Rover shop to ask them to get the two talking to each other again. That again took less than five minutes.
smokin
09-06-2013 01:19 AM
