Will unpluging the battery clear the 3 AMIGOS?
Old Jun 9, 2009 | 05:44 PM
VikingDiesel's Avatar
Default Will unpluging the battery clear the 3 AMIGOS?
Disco Mike told me that the brake squeal could very possibly be my reason for the 3 amigos and that I should have them cleared and put new brakes. But if I unplug the battery, wont it clear and then come on after the speed sensors sense the squeal again or no, it must be cleared by a special scanner regardless of the issue?
Old Jun 9, 2009 | 06:02 PM
Needs to be cleared by a ABS scanner.
Old Jun 9, 2009 | 07:35 PM
okdiscoguy's Avatar
special scanner.
Old Jun 9, 2009 | 07:37 PM
khuds308's Avatar
unplug the battery....you wish it were that easy huh =)
Old Jun 9, 2009 | 07:39 PM
Why waste your time trying to clear the codes before you fix the problem??
Old Jun 9, 2009 | 10:49 PM
to see if thats my problem
Old Jun 10, 2009 | 09:06 AM
So, are your new brakes squeaking? How about doing a panic stop, can you feel the ABS pulsate thru the brake pedal?
cammyr01
Jan 5, 2015 02:42 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
VikingDiesel
May 25, 2009 10:24 AM
loic
Nov 4, 2007 07:13 PM
rovernbama
May 15, 2006 03:03 PM
