Will This Work On A D2?
Old Aug 13, 2009 | 02:32 PM
RealRitzcracker's Avatar
Default Will This Work On A D2?
Will this rim work on a 2004 D2?
Rim Diameter (in) 15 in.
Rim Width (in) 8.00 in.
Backspacing (in) 4.000 in.
Offset (mm) -12.00mm
Lug Nut Seat Style Conical seat - 60 degree
Hub Centric No
Center Bore Diameter (in) 3.300 in.
Bolt Circle 5 X 4.75 in
Thanks
Old Aug 13, 2009 | 02:48 PM
jycsalas's Avatar
sorry i dont know about wheels on rovers. someone else will answer this im sure
Old Aug 13, 2009 | 03:31 PM
AK Rover's Avatar
No. Your bolt pattern is 5 on 120mm. Different bolt patterns are not interchangeable.
Old Aug 13, 2009 | 03:58 PM
120 millimeters = 4.72440945 inches
So that's a difference of .025 of an inch.
Sanding the paint off the holes would be .025 of an inch.
Old Aug 13, 2009 | 05:33 PM
4.72 inches vs 4.75 inches
You don't think that it will work?
Old Aug 13, 2009 | 07:13 PM
llPANCHOll's Avatar
You seem to be very confident..
Perhaps you should contact the wheel manufacturer
Old Aug 13, 2009 | 08:46 PM
I have ? which usually means your not that confident.
With 15" clear the D2 Brakes?
Was is the stock rim backspacing? (4.5", 6"?)
Thanks
Old Aug 13, 2009 | 10:02 PM
AK Rover's Avatar
Yes 15" wheels will clear the brakes. If you look you can find the same wheel you're wanting with the correct bolt pattern. Even with the slight difference they will not fit.
05LandRover
Feb 28, 2014 09:27 AM
armyeng
Mar 8, 2011 05:58 PM
winstonbike
Jun 1, 2005 01:56 PM
Off Topic
Apr 28, 2005 04:02 AM
dkdirt63
Apr 17, 2005 11:05 PM
