window jams on 02 DII
I have an 02 discovery that the window will jam on the way down. I can see it get off center before it jams up. If I hold the top front of the window then it will go down just fine. Has this happened to anyone before or does anyone have some ideas to look for? I took the door panel apart but did not see or could not see anything obvious. thanks
Check and you may see the that the roller wheel is broken. Replace the wheel and you should be good.
http://picasaweb.google.com/jycsalas...torFixerUpper#
http://www.jewellamberoil.com/sales/...roducts_id=185
I had the exact same issue with my 99 Disco II. The roller wheel was broken. I looked at replacing the wheel. Considering the price of the wheel and work required to replace it I decided to purchase a new regulator on Fleabay for a cost of $83.00, which included shipping. Good luck with your repairs.
twoxred
Oct 4, 2021 07:07 AM
phillman98
Dec 4, 2010 10:01 PM
Dan_da_LR3_H2_man
Jun 3, 2009 04:05 PM
