window jams on 02 DII
Old Jul 15, 2009 | 03:06 PM
selvisa's Avatar
4th Gear
Default window jams on 02 DII
I have an 02 discovery that the window will jam on the way down. I can see it get off center before it jams up. If I hold the top front of the window then it will go down just fine. Has this happened to anyone before or does anyone have some ideas to look for? I took the door panel apart but did not see or could not see anything obvious. thanks
Old Jul 15, 2009 | 03:49 PM
jycsalas's Avatar
Check and you may see the that the roller wheel is broken. Replace the wheel and you should be good.
http://picasaweb.google.com/jycsalas...torFixerUpper#
http://www.jewellamberoil.com/sales/...roducts_id=185
Old Jul 16, 2009 | 07:51 AM
selvisa's Avatar
4th Gear
thanks, I'll check out the rollers and let you know how it works out. Thanks for the detailed pictures on how to replace them
Old Jul 16, 2009 | 08:03 AM
jycsalas's Avatar
Welcome. You may find other options to replace the wheel at your local hardware store.
Old Jul 19, 2009 | 06:56 PM
bigun's Avatar
I had the exact same issue with my 99 Disco II. The roller wheel was broken. I looked at replacing the wheel. Considering the price of the wheel and work required to replace it I decided to purchase a new regulator on Fleabay for a cost of $83.00, which included shipping. Good luck with your repairs.
Old Jul 20, 2009 | 07:32 PM
dcreekmore44's Avatar
Default Regulator
I just replaced my front window regulator. Got it from Rovers North. It was just over $60. Worked perfect.
twoxred
Oct 4, 2021 07:07 AM
RedAustinIX
Aug 10, 2020 11:43 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
