Window Motors
Old Dec 7, 2024 | 01:07 PM
alw85's Avatar
Default Window Motors
Guys,
I found a company called Rimmer Bros and it looks like they carry oem style window motors and much much more. My question is would a window motor have the same foot print as the sunroof motors? I have one that I tried cleaning and it ended up burning out and need a replacement or someone to rebuild it.
Thanks
Old Dec 7, 2024 | 04:24 PM
Extinct's Avatar
No, they are different. Suggest you source one from a breaker, preferably from a desert environment (AZ, CA, etc).
Old Dec 9, 2024 | 07:18 PM
alw85's Avatar
I'd like to find a company that would reproduce them. Guess that's going to be a tough one to do.
Old Dec 10, 2024 | 07:26 AM
Extinct's Avatar
They basically never wear out, the mode of failure is internal corrosion due to the sunroofs leaking.
Old Dec 10, 2024 | 01:09 PM
Harvlr's Avatar
When I got my D2, the driver’s window motor was toast. At least in part due to the vehicle having been parked in the Vancouver rain with the window down for the previous 2 years. I took the motor from the left rear window and installed it in the front position (AFAIK the window motors on the same side of the car are identical). Then I ordered a cheap replacement motor for the rear (perhaps from Rimmer’s), reasoning that the original LR motor would last much longer in the front (where it gets way more use). 5 years later they both still work. As Extinct says, an original LR motor from a breaker is probably a better option.
zuke
Oct 4, 2020 12:44 PM
jdbayer
Jul 9, 2019 03:59 PM
jh.
Aug 7, 2013 03:59 PM
Cessna310Guy
Nov 15, 2008 07:31 AM
01DiscoII
Apr 9, 2008 03:57 PM
