Window problems
RE: Window problems
Yes, we all do, that is the "fly" feature, it is to let the flys out of the truck.
Sounds like you might have a bad window switch. Remove the panel that houses the window switches and unplug the drivers window and see if it still happens.
Just for fun plug the passenger window into the drivers spot and see if the pass window does the same thing.
RE: Window problems
Hell I dont know.
The cover should just pry out and then the switches will be in the cover.
These are the wrong switches but it will give you a visual.
http://www.roverlandparts.com/1995-2...eand46hse.aspx
twoxred
10-04-2021 07:07 AM
phillman98
12-04-2010 10:01 PM
Dan_da_LR3_H2_man
06-03-2009 04:05 PM
