Window problems
Old Sep 9, 2008 | 06:38 PM
sdsilvere38's Avatar
Default Window problems
Whenever I start my disco, the drivers window always goes down on its own. Anyone else have this problem?
Old Sep 9, 2008 | 06:52 PM
Default RE: Window problems
Yes, we all do, that is the "fly" feature, it is to let the flys out of the truck.
Sounds like you might have a bad window switch. Remove the panel that houses the window switches and unplug the drivers window and see if it still happens.
Just for fun plug the passenger window into the drivers spot and see if the pass window does the same thing.
Old Sep 9, 2008 | 07:59 PM
How do I get the switch out?
Old Sep 9, 2008 | 08:03 PM
Hell I dont know.
The cover should just pry out and then the switches will be in the cover.
These are the wrong switches but it will give you a visual.
http://www.roverlandparts.com/1995-2...eand46hse.aspx
twoxred
Oct 4, 2021 07:07 AM
RedAustinIX
Aug 10, 2020 11:43 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
