window question
Afternoon all,
Got in the truck today and tried to put the passenger side front window down and nothing - I can hear a (solenoid clicking) sound in the door. I don't want to yank stuff apart if its something simple - like say a fuse. = Have clicking sound in door when switch is actuated, window does not go down (I guess I should be thankful its up all the way!!!)
Any ideas????
Thanks to all that respond
Robert
Any ideas????
Robert
Sounds like your window motor may have stripped out some gears or the window itself has bound up. It is not difficult to remove the door panel and take a look. Just get a panel removal tool from your local parts store. There are 2 bolts in each end of the door handle and a screw in the handle release cover that need to be removed. Then you can use the panel removal tool to pop the panel off. Then carefully peel the plastic moisture barrier away from the door and see what is going on inside. Let us know what you find.
If the window is bound can I apply pressure to it while the wife works the switch? Is that a good try???
Will remove the panel to see whats up - probably wont happen till this weekend tho
Thanks
Thanks
twoxred
Oct 4, 2021 07:07 AM
phillman98
Dec 4, 2010 10:01 PM
Dan_da_LR3_H2_man
Jun 3, 2009 04:05 PM
