window regulator in,,,
Old Nov 24, 2008 | 08:15 PM
sloppyjoe's Avatar
Default window regulator in,,,
well now when the other inevitably fail i will know how to replace the regulators. was really not a hard job at all. took maybe an hour in all.
Old Nov 25, 2008 | 08:52 AM
Cessna310Guy's Avatar
Default RE: window regulator in,,,
sloppyjoe, I have been through the same route... both front door window regulators... Can you buy new plastic seals that go under the interior panel...? where is the best place if you know of one...?
Old Nov 25, 2008 | 10:45 AM
sloppyjoe's Avatar
you mean the plastic sheet? i did not remove it, just worked around it,,
Old Nov 29, 2008 | 07:21 AM
I did that when I replaced the RHFD window motor... When I discovered the LHFD Reg. went bad I was somewhat mad and simply ripped the plastic off... SO, I need to locate a new one ...
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
garover
Mar 28, 2005 08:44 PM
