Window regulator or motor?
Hello, I had a drivers window fall down and not come back up on a 2003 Discovery. I took out the window and regulator to evaluate the problem. I reconnected the window motor to make sure it still worked...and all it did was make a clicking noise. I suspect that the motor must be an issue instead of the regulator.
I wanted to make sure that all I need is the motor and not a regulator. I did notice though that one of the plastic rollers is broken and I did see a metal roller mentioned when doing a forum search on this topic. But I'm not sure how it really gets installed...could anyone clarify for me on that?
Thanks.
Thanks.
I finally got all the parts replaced I needed to get that window working again. As I was putting everything back on, I saw that there was an extra connector at the side mirror that I couldn't figure out where it goes. There were two connectors, one big one and one small one at the side mirror. I connected the big one. Now, I'm not sure about this small connector. I can't recall if it was connected or not... Does anyone know where this would go? I couldn't locate any loose connectors at the time.
Thanks!
Thanks!
Al Blue4.6l
08-14-2011 05:28 PM
bcolins
10-20-2008 10:52 PM
