Window regulator or motor?
Old Mar 25, 2009 | 09:54 AM
david1289's Avatar
Default Window regulator or motor?
Hello, I had a drivers window fall down and not come back up on a 2003 Discovery. I took out the window and regulator to evaluate the problem. I reconnected the window motor to make sure it still worked...and all it did was make a clicking noise. I suspect that the motor must be an issue instead of the regulator.
I wanted to make sure that all I need is the motor and not a regulator. I did notice though that one of the plastic rollers is broken and I did see a metal roller mentioned when doing a forum search on this topic. But I'm not sure how it really gets installed...could anyone clarify for me on that?
Thanks.
Old Mar 25, 2009 | 10:44 AM
Normally the nylon roller fails on the window regulator, sometimes the arms bend and pop the rivots. If the motor is clicking better get it all.
Consider going to Roverlandparts.com for a great price on used guaranteed parts.
Old Mar 25, 2009 | 11:30 AM
AK Rover's Avatar
Generally if the window just falls like that it's a failed regulator. Sounds to me that you have a failed regulator and a bad motor.
Old Mar 25, 2009 | 11:57 AM
david1289's Avatar
OK, thanks guys! I will go ahead and get all the parts then. Thanks for that website. They are certainly cheaper than the new prices!
Old Mar 30, 2009 | 10:28 AM
david1289's Avatar
I finally got all the parts replaced I needed to get that window working again. As I was putting everything back on, I saw that there was an extra connector at the side mirror that I couldn't figure out where it goes. There were two connectors, one big one and one small one at the side mirror. I connected the big one. Now, I'm not sure about this small connector. I can't recall if it was connected or not... Does anyone know where this would go? I couldn't locate any loose connectors at the time.
Thanks!
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
darrenh1975
Aug 5, 2007 03:41 PM
zachbraff
Jul 18, 2005 12:57 AM
