Window Regulator Replace with Pics
Hello all,
Wanted to contribute. I replaced my Drivers side Door Regulator. Removing the panel is easy. Just remove the phillips head screws. Then use a 1" gasket remover tool on all the edges to pop the fasteners out.
8mm socket to remove all the bolts holding the regulator on as well as the bolts holding the glass. Phillips screw holds the plastic glass clip. Torx 30 to remove the motor from the old regulator. Pics should show the procedure.
Regulator part number for Drivers side Front: LR006374
Al Blue4.6l
08-14-2011 05:28 PM
phillman98
12-04-2010 10:01 PM
