Window Regulator Replace with Pics
Old May 22, 2015 | 12:48 PM
MPDano's Avatar
Default Window Regulator Replace with Pics
Hello all,
Wanted to contribute. I replaced my Drivers side Door Regulator. Removing the panel is easy. Just remove the phillips head screws. Then use a 1" gasket remover tool on all the edges to pop the fasteners out.
8mm socket to remove all the bolts holding the regulator on as well as the bolts holding the glass. Phillips screw holds the plastic glass clip. Torx 30 to remove the motor from the old regulator. Pics should show the procedure.
Regulator part number for Drivers side Front: LR006374
Attached Thumbnails Window Regulator Replace with Pics-20150522_092735.jpg   Window Regulator Replace with Pics-20150522_092741.jpg   Window Regulator Replace with Pics-20150522_092745.jpg   Window Regulator Replace with Pics-20150522_092749.jpg   Window Regulator Replace with Pics-20150522_093518.jpg
Window Regulator Replace with Pics-20150522_093748.jpg   Window Regulator Replace with Pics-20150522_094104.jpg   Window Regulator Replace with Pics-20150522_095730.jpg
Old May 22, 2015 | 02:05 PM
acg's Avatar
acg
Thanks for the info. I enjoy such posts where it will be useful reference for the future.
**Thumbs Up!**
Old May 22, 2015 | 03:08 PM
zeroone's Avatar
One of the many things on the Disco-Do list.
Old May 22, 2015 | 06:24 PM
OffroadFrance's Avatar
Good write up with pics. I did my drivers window recently and it's exactly as your write up.
Old May 23, 2015 | 10:02 AM
MPDano's Avatar
Thanks guys. I am getting a lot of great tips on these forums. It was time for me to give back. More to come.
RedAustinIX
Aug 10, 2020 11:43 PM
thehun
Mar 7, 2013 01:35 AM
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
