Windscreen leak
Old Aug 9, 2018 | 06:59 PM
redrover75's Avatar
Default Windscreen leak
I have the TSB regarding the sealant to fix the leaks around the windshield. However, the photos are not very good and I cannot tell if the upper pillar is where I leaking. Do the below photos show a possible source of leak? My front seat floors get wet after a rain.
Or, any other ideas about where the leak can be coming from?
Attached Thumbnails Windscreen leak-20180809_194120.jpg   Windscreen leak-20180809_194223.jpg
Old Aug 10, 2018 | 10:19 AM
Richard Gallant's Avatar
There is a curved rubber piece at the top corner of the windshield, warm it up (hot water or hot weather) roll it back. There was both a huge cavity and pine needles behind mine. Filled with silicone, put the rubber back in place with a bead underneath. No leaks since.
Also check your windshield cowl, it should be tight the windshield and intact no cracks. You can get water through that area to the passenger side.
Old Aug 10, 2018 | 11:05 AM
Saturnine's Avatar
So these pics are up top, looking down the A pillar, right?
Old Aug 10, 2018 | 12:37 PM
Dave03S's Avatar
I had a leak in that spot right after a new windscreen installation. Clear silicon under the rubber worked for me. I cleaned it out first with a toothbrush and compressed air.
Richard Gallant
Sep 16, 2019 03:35 PM
garydebergerac
May 27, 2014 02:28 AM
ZB-30
Mar 26, 2014 11:47 AM
oilspotLR
Jun 7, 2012 10:49 AM
