Windscreen Washer
Old Oct 3, 2013 | 01:09 PM
james.martin1's Avatar
Default Windscreen Washer
I've started to go through my Disco today and fix some of the smaller issues that have been coming up. I noticed when trying to use my windshield washer that the the pump was working fine but it was just pumping fluid out of a disconnected rubber hose. The hose comes out of a fitting on the left side of the engine bay but I can not find what fitting it is supposed to hook up to. Since the fluid pumps out of the hose it must be the one that connects the pump to the wipers. Does anybody have any ideas about where this line is supposed to go?
Old Oct 3, 2013 | 02:15 PM
dusty1's Avatar
jets for headlights? they run along front and there is long length going to rear glass. light hose go straight down and Y (one left and one right). back glass hose runs along drivers side front panel. iirc there is another L connection close to firewall, running with wire loom, on dside (but that may be some ghetto fab that I created while relocating my washer bottle)
Old Oct 10, 2013 | 06:23 PM
Default Some issues fixed, others still at large.
I have not checked to see if the headlamp washers work. The hose that is disconnected is supposed to go to the windshield wipers.
I was successful in clearing my CEL today. I had the left and right bank lean codes as well as the 3rd gear ratio incorrect code. I found out from other threads on here that it is a MAF sensor issue. I pulled out the sensor and the hotwire was covered in black gunk. I cleaned it with aerosol elec parts cleaner and covered the connector with di-electric grease. I cleared the codes and have not had the CEL on since.
Old Oct 10, 2013 | 07:56 PM
dusty1's Avatar
Good deal
yallie
LR4
Aug 7, 2011 08:23 PM
krazzz
Jan 15, 2010 07:17 AM
egb
Freelander
Nov 27, 2008 03:14 PM
englishboyonice
Aug 18, 2005 07:23 PM
DiscOwner
Mar 25, 2005 03:55 PM
