Windshield sprayer no pressure
Old Mar 7, 2009 | 08:37 PM
JBEGIN's Avatar
Default Windshield sprayer no pressure
ive tried inserting a pin in the little sprayer eyes and clean out anything in there, its pretty clean. then filled up washer fluid jug and thought maybe that would do it, but it still barely comes out when i hit the switch for the squirter. this is really annoying since that sprayer used to blast washer fluid out of there with a vengeance, now it just mysteriously has no pressure behind it. what do i need to do?
Old Mar 7, 2009 | 08:48 PM
AK Rover's Avatar
Are we talking front, rear or headlight sprayer? Sounds to me like your pump for the effected sprayer is dying.
Old Mar 7, 2009 | 08:57 PM
JBEGIN's Avatar
ALL my sprayers! i dont even think the headlight sprayer works, never had someone look till after this problem surfaced. but definitely the rear doesnt do much, the front hardly anything, and the front headlight nothin.
Wheres the pump ???
Old Mar 7, 2009 | 08:58 PM
Sounds like you need a new pump.
www.roverlandparts.com
www.atlanticbritish.com
Old Mar 7, 2009 | 09:14 PM
JBEGIN's Avatar
apparently there are multiple pumps. each sprayer has a separate pump, so i might be replacing all of them if i need to. hopefully someone here will offer a solution to this problem as i said before, it worked very well before and now its messed up.
Old Mar 7, 2009 | 09:54 PM
tornado_735's Avatar
Pinched feed line maybe? I had this happen before. Check the lines for kinks or places where it might be pinched.
Old Mar 7, 2009 | 10:11 PM
grussell's Avatar
Pull your washer tank loose and position it where you can see the pumps. One at a time remove the hose coming off of each pump while someone turns on the washers. Remember the headlight washers will only work if the headlight are on. I had the same problem and all pumps worked. There are little one way valves in the hoses coming out of the pump that were stopped up on mine. They would let very little washer fluid pass through. When I removed them and checked the pumps, washer fluid flowed good.
Old Mar 8, 2009 | 08:48 AM
Remove all 3 pumps, flush our the bottle then blow small amount of pressure thru the sprayer lines.
Old Mar 8, 2009 | 06:56 PM
JBEGIN's Avatar
well today i went out and did some investigating. took out both hood squirters and ran a torch-tip cleaner in the holes where fluid comes out of them, that gave me a little better spray but didnt completely resolve the problem. so im gonna see if i can locate replacement hood sprayers and it should be the end of it.
mitchkohn
Aug 25, 2013 08:28 PM
Benhamtroll
Apr 21, 2009 05:31 PM
73S3IP
Feb 1, 2009 10:55 PM
Camdisco24
Apr 17, 2008 12:24 PM
