Windshield Wiper tip
Old Jan 11, 2010 | 06:24 PM
Princess's Avatar
Default Windshield Wiper tip
I have a 2000 Disco II. This tip probably would work for all of the Land Rovers.
I noticed I wasn't getting clean sweeps from the wipers. After looking into how they work closely I noticed there is a spring that needs to hold the wiper on the windshield all the way across. On my Disco II the wiper arm where is pivots near the base was not moving freely. It moved but didn't snap back to the windshield quickly as it should, and would stay a little off the windshield.
Solution: I took some penatrating oil and put it on the post where the pivot is. Worked it back and forth until it moved very freely. Now it snaps back on the windshield nicely like it should.
Test for it is to pull the wiper up a few inches and if it snaps down you are ok. If it doesn't go back on its own or feels tight you might need to fix it for better functioning.
Mike
Old Jan 11, 2010 | 06:42 PM
lipadj46's Avatar
I use winter blades year round they work much better.
Old Jan 11, 2010 | 07:51 PM
Triple Edge blades for me.
Old Jan 11, 2010 | 08:27 PM
Princess's Avatar
Where is the best place to get wipers? I went to Napa and they were $40.00 each!
Old Jan 11, 2010 | 08:40 PM
lipadj46's Avatar
They are expensive. The winter blades at AB are even $65. They say they are made by the OEM maker though. They will go on sale for $50 or even $35 eventually.
Old Jan 11, 2010 | 08:51 PM
bikingteacher's Avatar
I did that on the front--much better now. Anyone have issues with the rear. I only get a partial wipe--very little contact with the farthest part of the wiper. I use it quite a bit in the winter now from all the salt spray.
Old Jan 11, 2010 | 09:15 PM
Jst4fun's Avatar
I went and bought some generic refills for around six bucks and carefully removed the old blades and installed the new ones. Worked great :-)
Nick
jmt
Apr 6, 2008 05:18 PM
afphinfan
Jan 6, 2008 10:47 AM
Mark G
Oct 4, 2007 11:38 PM
RoverCam
Mar 20, 2007 12:45 PM
sopjih
Sep 9, 2006 02:38 PM
