Wiper Blades stopped working in mid swipe
on
Better describe the intermitent problem before they parked/stopped.
There is also the possibility that your park switch inside the motor has failed. By the way, how did you move the wipers back into the down position, if you didn't loosen the nut on the pivot point first, you may have also stripped out the pivots.
They would get stuck at the top, then a few seconds later swipe down. Then stop. Then swipe up, get stuck (without going all the way up), then eventually swipe down (and stop). repeat.
until the other day, when they just stopped.
I got out of the car, and manually lifted the drivers' side one a bit, until it easily flowed back down along with the passenger side one in unison.
And there they sit, dormant. and it's snowing out.
I'm not a mechanic, I'm no good with cars. What would you suggest?
tsuyoi
09-22-2020 10:37 AM
