Wiper System Troubleshooting
We had some good snow here ice here in Texas last week.
My brother had my D2, and he says that the wipers "stopped working".
I wouldn't put it by him to have tried to operate the wipers while they were frozen to the windscreen.
I have not yet inspected it myself yet (am getting the D2 back from him today), so I admit I am flying a bit blind here.
Brother claims motor is not running, but I haven't independently confirmed that.
I read up on the system in the workshop manual, and it seems like there are a lot of possible electrical failure points in addition to the linkage: BCU, IDM (which is integrated into the fuse panel?), relay (also integrated into the fuse panel?), motor.
Anyone have any advice on how to start approaching this assuming it is not a mechanical issue (I've seen the nuts loosen and wipers work their way off the linkages stubs on frozen blades before).
FYI, separately, I am replacing the arms with D1 versions so I can just buy standard blades.
Another common issue is the stalk stops working. You can remove it and rebuild it with not too much trouble. It can be tricky removing it due to the tabs being in a weird place. Don't force it. Once off take it apart, clean all of the contacts, regrease and reinstall. There is a youtube video for it.
Thanks all.
I finally got to the beast and here are the tests I performed.
Confirmed there is power at fuse 19 (and that the fuse is good.
The front wipers, front washers and headlight washers don't make a sound when engaged at the stalk control.
However, the rear wiper and washer performs fine (and you can hear the whirring of the rear washer pump) and as the rear wiper-washer goes thru the BCU and IDM as well, for now I am assuming that those are not the issue.
So right now I am going with the wiper control stalk, though my normal experience is that these don't typically fail all-at-once but rather start failing intermittently at first, which is not the case here.
Can you point me to the video of how to renew it as I cannot seem to find it.
I've had the steering wheel and collar off before and that was pretty easy (after letting the electrical system de-energize for 15-30 min first). Is the trim piece around the steering shaft held on with torx or phillips -- I can't remember?
Here is a video for the headlight side and it goes on the same for the wiper switch.
. You might look for others and search for Discovery 2 headlight switch replacement. The trick is inserting the small thin screwdriver to pop it out. This guy has a pretty big screwdriver, I would use the thinnest you have. Once off it's pretty obvious how to fix it. I didn't need to remove the steering wheel.
Oh noo... Where is the rest of the story... I seem to be having the same exact issue, still need to get to the car to test the fuse (hope that may be it) or else I will have to do the stalk cleaning though it is strange that it may have just broke down without any real prior issues... This happened after a rain +freeze storm...
