Wipers working intermitently!
Old Jan 7, 2014 | 01:57 PM
Dan7's Avatar
Default Wipers working intermitently!
Sometimes I turn the wipers on and nothing happens. Sometimes after a couple minutes, they start working suddenly. It is possibly temperature related (once the car warms up, it works) but can't be sure. Also, sometimes they work just fine. So far however, once they start working, they stay working. They don't suddenly stop working after they've started.
This is kind of an emergency as we're getting a lot of snow right now and last time I about ran off the road blind. Appreciate the help up front.
Old Jan 7, 2014 | 08:03 PM
Avery Hindman's Avatar
4th Gear
Happens with my 2003 Disco as well I found that if you press the washer fluid button the wipers will always work i use that to get them warmed up
Old Jan 7, 2014 | 08:17 PM
dgi 07's Avatar
its the switch. The greasy goo in the switch gums it up......give me a minutes and i'll add the link to fix it...
https://landroverforums.com/forum/di...tch-fix-46886/
ask and you shall receive. when you turn on the heat and aim the vent at the switch it heats up and starts workin. mine did the same thing..
Old Jan 8, 2014 | 08:42 AM
Dan7's Avatar
Going to give this a try today.
Old Jan 8, 2014 | 11:07 AM
Dan7's Avatar
Before cleaning:
After Cleaning:
That stuff didn't come off easy...glue is an accurate description! 5 Q-tips & some break parts cleaner over about 5 minutes got it that good. Going to use the dremel brush wheel for good measure. We'll see if it worked. Fingers crossed as a new unit is $330 from AB and out of stock.
Old Jan 8, 2014 | 04:48 PM
catman's Avatar
It'll work, just be sure to coat the areas with fresh dilectric tune up grease (like Permatex), not bulb grease or vasoline or anything like that or it will act up again down the line.
Old Jan 8, 2014 | 08:44 PM
Dan7's Avatar
Success! Thanks dgi 07 for the link and CANAMDiscovery for the write up. Another headache made easy!
Old Jan 8, 2014 | 10:56 PM
CANAMDiscovery's Avatar
If you ever have trouble with the turn signal stock, you will be able to do the same thing.
Glad it worked.
Pretty obvious the issue once the switch is opened up.
tsuyoi
Sep 22, 2020 10:37 AM
LoneBiker
Freelander
Jun 7, 2012 01:56 PM
funatic
Jan 31, 2012 03:28 PM
jonasm
Dec 23, 2008 05:51 AM
mrdarcy
Freelander
Feb 1, 2007 03:34 PM
