Wiring O2 sensor
Old Aug 13, 2016 | 04:55 PM
NorCal Rover's Avatar
3rd Gear
Default Wiring O2 sensor
Hello All,
I have a 2000 discovery 2 with 120,000 miles on her with a 4.0. While wheeling in the mountains I went over a large branch on the ground. It jumped up and ripped my O2 sensor connectors (male and female) clean off. It of course threw a code but I didn't realize the issue until I was back home. My question is what is the wiring sequence for the vehicles side of the connector. I have a new O2 sensor with a connector. Just need to rewire the other side correctly. It is the post cat drivers side.
Any help would be greatly appreciated.
Old Aug 13, 2016 | 08:02 PM
jfall's Avatar
Look at the rear or front sensor which is not ripped off.
Match the colors.
Two wires are 12 volts - one will be 12 volts.
One will be ground.
ANd there is signal ground for the sensor.
And the output from the voltage producing sensor will be the last wire.
https://www.google.com/#q=bosch+oxyg...wiring+diagram
KlamathMatt
Apr 17, 2020 05:27 AM
kevin cassidy
Jan 30, 2012 12:42 AM
ttlandroverdisco
Oct 14, 2010 09:44 PM
imaric
Sep 28, 2010 09:04 PM
twmj1953
Jun 29, 2010 08:59 PM
