wont come out of park
Having ithe RAVE on PC hard drive is faster than the CD rom, for $100 you could have it printed (sections of interest).
Here's pages for you, hope that all that one or two connectors were all that was missed when swap was done. This is under the automatic transmission section of the workshop manual, and shift interlock section.
No Buzz, all cars have a neutral safety switch, they all work the same way, it is a on-off switch, take the 2 wires that power the relay and wire them together, no more neutral safety switch.
The switch tells the ECU to release the park lock on the transmission as well as to send power to the starter.
The OP also needs to check the brake light switch, turn the key ON and press on the brake pedal, do the brake lights come on?
No?
You need a new brake light switch, if that is bad you will not beable to shift out of park.
No?
