Wont continue upon starting.
Hi there,
The last time I used my Disco was about a month ago. It runs and it starts well. Today, I was trying to start it and it wont continue to run. It cranks, almost about to run but really wont continue. Any advise please. Any trouble shooting guide? Thank you
Does the engine fire up and then shut off? Or will it not fire at all, just cranks?
Your description is rather vague leaving us to ramble off guesses.
It could be a number of things, but we need to know a little more in order to provide a solid diagnosis.
Off Top of head:
Fuel pump relay
Fuel pump
Crank position sensor
Low fuel
Off Top of head:
Fuel pump relay
Fuel pump
Low fuel
How often have you used it since you last filled with fuel.
Bad fuel maybe?
Mouse living in your Maf?
Edit, thinking more. Whenever I forget to reconnect the Maf after messing about around there I get a similar symptom you describe. Check those connections.
Is there a way to physically check the Maf is operating? I guess it would throw a code at the least.
Bad fuel maybe?
Thank you guys. Got enough fuel over 1/2. Its very technical to describe but when I turned the key, it fires up, I see the smoke from tail pipe, but it hesitate to continue then dies. Last month when I used it, all went well except that I have not started the LR for a while about a month.
Can a weak battery cause it?
I bought a new battery last mid September.
Off Top of head:
Fuel pump relay
Fuel pump
Low fuel
Off Top of head:
Fuel pump relay
Fuel pump
Low fuel
Bad fuel maybe?
Bad fuel maybe?
95RRCLWB
06-20-2014 07:47 PM
Kyra96Disco112
11-12-2011 08:19 AM
