Wont continue upon starting.
Old Dec 3, 2015 | 04:35 PM
LR03NJ's Avatar
Default Wont continue upon starting.
Hi there,
The last time I used my Disco was about a month ago. It runs and it starts well. Today, I was trying to start it and it wont continue to run. It cranks, almost about to run but really wont continue. Any advise please. Any trouble shooting guide? Thank you
Old Dec 3, 2015 | 10:07 PM
coors's Avatar
Any fault codes stored? Check engine light illuminated? Is your fuel level above a quarter tank?
Old Dec 3, 2015 | 10:26 PM
Twix's Avatar
Crank sensor? That's the only thing that comes to my mind. Check for codes, there might be something stored that isn't causing the light to illuminate.
Old Dec 4, 2015 | 06:54 AM
coors's Avatar
Does the engine fire up and then shut off? Or will it not fire at all, just cranks?
Your description is rather vague leaving us to ramble off guesses.
It could be a number of things, but we need to know a little more in order to provide a solid diagnosis.
Off Top of head:
Fuel pump relay
Fuel pump
Crank position sensor
Low fuel
Old Dec 4, 2015 | 07:51 AM
cappedup's Avatar
How often have you used it since you last filled with fuel.
Bad fuel maybe?
Mouse living in your Maf?
Edit, thinking more. Whenever I forget to reconnect the Maf after messing about around there I get a similar symptom you describe. Check those connections.
Is there a way to physically check the Maf is operating? I guess it would throw a code at the least.
Old Dec 4, 2015 | 08:35 AM
batard's Avatar
Assuming it's cranking but not starting, the standard next diagnostic steps are to make sure you have fuel and spark.
Old Dec 4, 2015 | 01:31 PM
LR03NJ's Avatar
Thank you guys. Got enough fuel over 1/2. Its very technical to describe but when I turned the key, it fires up, I see the smoke from tail pipe, but it hesitate to continue then dies. Last month when I used it, all went well except that I have not started the LR for a while about a month.
Can a weak battery cause it?
I bought a new battery last mid September.
Old Dec 4, 2015 | 01:33 PM
LR03NJ's Avatar
Off Top of head:
Fuel pump relay
Fuel pump
Low fuel
Exactly, it fires up and then shut off immediately. I think it fires up since I see smoke from tail pipe while it cranks. Any diagnosis that I can do?
Old Dec 4, 2015 | 01:34 PM
LR03NJ's Avatar
Bad fuel maybe?
Thanks, Ill check the MAF. But never touch engine.
Ghaniba
Jan 15, 2015 02:55 PM
Kyra96Disco112
Nov 12, 2011 08:19 AM
paul rod
Oct 25, 2011 09:19 AM
rravenn13
Jun 18, 2007 12:49 PM
