Won't crank
Old Jun 27, 2023 | 07:55 PM
Triddell62's Avatar
Originally Posted by Extinct
Hmmmm, 4 and 8 have almost nothing in common other than the side of engine. I would normally swap plug wires as a start with cylinders than are not throwing code, and then plugs. I like to compare known good with suspected bad. You can swap the knock sensors left and right to see if that is the issue.
will do
did a compression test, all cylinders were between 157 to 160. Except no 8, which was 145. There was oil on the threads.
btw the engine has 303k miles on it
Old Jun 27, 2023 | 07:57 PM
Triddell62's Avatar
Swapped plugs and erased codes. Still getting cylinders 4 and 8 misfire. And knock sensor 1 circuit low input.
going to swap wires over the weekend. Its a big pain with the SAI
ononomos
Jun 26, 2021 04:03 PM
ge234
Oct 22, 2017 11:46 AM
StaceyBritton1970@gmail.com
Jun 14, 2016 12:13 AM
Huuflungpoo
Mar 5, 2015 07:27 AM
cellman01
Jul 28, 2009 06:44 PM
