Won't Crank, Passive Immobilization...Any Tricks?
Fault Code 1668 - Fix for me
Sorry to revise this old thread, but I hope I can provide information to help people who are getting the passive immobilization code (Fault Code 1668) like I did after my truck refused to start. Based on my review of the technical bulletin around this code, I thought it was a Body Control Unit issue that required either replacement or reprogramming of the unit. After towing the car to my mechanic, I found out that the issue was not the BCU, but the starter motor. Replacing the starter motor fixed the problem.
That is not to say that the starter motor is the only answer to this code. For all I know there is a less expensive solution. Or it may be the BCU after all for some. Either way, am hoping to contribute info on possible solutions.
12RRA
06-26-2014 05:01 AM
audiS4S6
04-30-2010 09:40 PM
alpinab7
11-27-2006 07:34 PM
