Won't reverse after low 4wd cable replacement
Old Oct 28, 2020 | 09:47 PM
Abbott57's Avatar
4th Gear
Default Won't reverse after low 4wd cable replacement
2004 D2 . I can't get it to go backward after putting it in reverse after we replaced low 4wd cable. Could I be the first this has happened to? Thinking of turning this beauty into parts truck.
Old Oct 29, 2020 | 07:27 AM
Red5's Avatar
Do you mean that the truck will not roll backwards, or that the trans will not shift into R? Can you drive forward in other gears?
If the low range cable is not adjusted properly, the shift fork could be between L and H. This puts the transfer case in N, but in this case you would lose drive entirely, not just R.
Old Oct 29, 2020 | 07:43 AM
Abbott57's Avatar
4th Gear
I can drive forward , and shift into reverse, but it will roll reverse for about a foot then stops on a dime
Old Oct 29, 2020 | 08:37 AM
mollusc's Avatar
Undo the range shift cable at the case end, and move the shift lever manually to make sure it's in the correct position -- either high or low shouldn't matter. Then try to reverse again. That should confirm whether it's a problem with the cable adjustment.
Also confirm that the CDL is unlocked, since the shifter on the 2004 is connected to both.
Old Oct 29, 2020 | 09:10 AM
Abbott57's Avatar
4th Gear
Thanks so much . I will try when thunderstorms pass today. !
Brice R. Pecnik
Dec 10, 2018 04:49 AM
TRIARII
Mar 28, 2017 08:28 PM
nigelryoung
Feb 23, 2015 07:01 AM
toofaroffroad
Dec 30, 2012 11:51 AM
ColoDisco
Jul 26, 2011 06:28 PM
