wont start
IT turns over. Sounds like it will start, just wont. When this happenned, I turned the key and it started but when I let off the key it stopped and wont start since then. I dont hear clicking when I turn the key to start possition. I dont think I turned the key all the way like I normally do. Everything has run perfect up til this.
OK I just tried again. I do hear a click near the passenger floorboard. Is this the fuel pump relay? I opened the gas cap and put it back on, and I turned the key to the on possition a few times before trying to start. Just cranks, wont start!!!!!
The gas cap has nothing to do with this.
Press the little tire valve on the engine fuel rail with a screw driver, if fuel squirts across the driveway you have fuel pressure.
If not then you have a fuel delivery problem.
If yes then you have a spark problem and you need to remove one spark plug and hook the plug wire back up and have a friend crank the engine over while to check to see if the spark plug sparks.
