wont start
Old May 31, 2010 | 11:10 AM
Does your fuel pump come on?
Put your ear to the floor in the cargo area and have a friend turn the key to the "ON" position, you know the one, the one where all the dash lights come on but NOT the one where you crank the engine over.
Do you hear the fuel pump come on?
It should come on and run for 15-30 seconds and then shut back off.
Old May 31, 2010 | 11:11 AM
reddisco's Avatar
Where is the fuel pump fuse and relay? With the fuses under the hood on passenger side? There is also a smaller black box with 2 wire harnesses on it near the fuses, what is this? I ask cause it is not mounted anymore, it broke off the mount.
Old May 31, 2010 | 11:44 AM
reddisco's Avatar
Fuel pump fuses are good. Not sure where relay is though.
Old May 31, 2010 | 02:13 PM
Does the fuel pump come on?
The fuel pump relay is under the hood.
Old May 31, 2010 | 07:01 PM
reddisco's Avatar
I dont hear the pump turn on. So, is it the pump or relay? or both
Old May 31, 2010 | 07:21 PM
Danny Lee 97 Disco's Avatar
What I would suggest is to clear out the rear cargo area, lift the carpet, mats and pad or whatever is left in yours. There is a black metal plate screwed into the floorboard. Remove the plate (6 screws I think it was).
You should then be looking directly at the top of the fuel pump/sending assembly. There is a connector on the left side. You can check there for the 12 volt input to the fuel pump. If you do have the 12 volts, the fuel pump is bad.
I recently replaced mine due to a split in the line at the plastic top of the fuel pump sender assembly. A brand new ProLine assembly for my 97 was only $105 from Rovers North.
Old May 31, 2010 | 07:45 PM
reddisco's Avatar
Just checked Rovers North. They show 2 pumps for Discovery series 1. One is $244, the other $525, OUCH!!!
Old May 31, 2010 | 07:49 PM
You need to know what EVAP system you have, the advanced evap loss system is the expensive one.
And no they are not interchangeable.
http://www.roverparts.com/TechTips/k...ons_system.cfm
I bought my fuel pump at AutoZone last year, $450.
Old May 31, 2010 | 08:05 PM
reddisco's Avatar
Standard Evap system.WHew! Saw the proline pump/sender on Rovers North for $104. Was this an easy repair? Or leave it to a pro? Looks like an easy swap. Any tricks to doing this/ special steps?
Old May 31, 2010 | 08:41 PM
Once you have all the parts it should only take you a hour.
Check locally for a fuel pump too and see if you can save on shipping.
The hardest part is getting the retaining ring off.
